91 Renagade
this smmer igot a set of 33s on renagade rims so i through them on a lil tight with no lift then te nextday went out with the juys from twin rivers offroaders
Anything can be done. Have a look at my (de)Renegade rebuild thread, in sig.
It may be worth finding a new tub. It was for me. Even thou this tub isn't close to perfect, it's wayyy faster, cheaper and easier to save a few bucks and buy a half decent tub and fix it instead.
that IMO is a prime opportunity to boat side the tub and cut out all of the rust. but if the tub looks real bad be prepared to be replacing body mounts etc.
good luck with the build.
i already have the 2 bodymounts that need replaceing right by the roll bar i have a welder and lots of cuttin disks im ready lol i may do steel plates around the skirt as i am not sure if i am doining the renegade kit anymore it holds to much crap asmuch as i like the difference from most people
^ if you ever start playing on the rocks you will tear off any of the skirting easily. I would recommend that you remove the renegade package and sell it to recoup some of the costs.
as for boat sides there are several ways to do them. Have a look at my thread you will see my version of how to build a YJ, including boatsides. Its nice to see another YJ reserrected. Again good luck on the build I will watch to see how you choose to build it.
EDIT:
also, the interweb box is a great tool. research, research, research. It will give you ideas and advice on what to and what not to do.
You have alot of work ahead of you H3lzs!
If you need a hand let me know!
Did you decide to fix or replace the frame?
Time to put some 4" lift springs in![]()
i am replacing it i am working out a deal on one right now actually my frame is cooked from one end to the other
i am leaning towards soa on older 2.5 lift springs so about 6 inchs altogether
i am going back to school in pembroke so its going to be a slow pace for it now![]()
i will definatly be in need of help to remove the tub
Good idea on getting a new frame. Did you talk to Scotty Behm? He has a couple YJ's in his yard.
While you are at it maybe it would be a good idea to get some rear leafs with a little offset so you can stretch the rear axle back a bit.
What are you going to be taking?
Send me a message when you need a hand.
scottys frames are rotten i want to keep it the same wheel base till i retire it from road use
i am taking motive power tecnition aka mechanic
will do
no extra progress till i find a frame i have one in my sights though so we shall see how it goes
if your getting rid of the Renegade package, i would be interested in taking it off your hands!
rev. if it was up to me i would sell it to you unfortunatly my girlfriend wants it and wants me to get and build her a jeep funny how that works lol
if the frame is chewed... I would make a new one, they are simple to make with the correct tools and knowledge. check out some builds on pirate and see how people are doing it.
just sayin
